2009 H3 3.7 three horn honks as key turns NO code
Old Sep 7, 2025 | 08:07 PM
NMH3's Avatar
Originally Posted by gaber6
Sorta standard, but with a trunk button. I tried a new battery in the remote today, too. I'll wiggle under and see where that little box connects and see if that resolves the issue. I have had the H3 for 4 months and this just started a few days ago.
Looks like its some type of dealer installed alarm system designed to protect cars on the lot and makes the sales guy's job easier by having a master fob to lock doors of different cars. Found a good discussion of it here: https://www.odyclub.com/threads/thre...-to-on.363346/
Old Sep 8, 2025 | 09:43 AM
gaber6's Avatar
SOLVED
Went out this morning to uninstall the little box under the dash. I felt around under there and there were 4 or 5 cut wires tucked into the carpet without tape on the end, presumably attached to that controller at one point.
I slept in the front seat twice at rest stops this week while driving cross country (19.2mpg at 73mph) and must have made one of the wires touch the metal beneath the carpet while kicking around.
I pulled the wires out and no beep on start.
Thanks for the ideas and information. I'll likely be installing my UCAs and front diff seals This week before my 2100 mile drive back.
Old Sep 8, 2025 | 11:22 AM
gaber6's Avatar
Well sort of solved... Must be something else related. I'll try to fully uninstall the thing later this week
Old Sep 8, 2025 | 04:13 PM
Btw, Walmart InHome delivery trucks do the same when closing the rear door. I get deliveries many times a week! I allow them to back the truck into my driveway to unload from the rear door then after closing the rear door, there's always 3-loud horn beeps. Probably pisses off the nutcase neighbor across the street, not me.
Old Sep 8, 2025 | 04:40 PM
gaber6's Avatar
That makes me wonder if there is a hood sensor. I just sprayed a **** ton of silicone on the hood latch last week too.
Old Sep 9, 2025 | 09:01 AM
gaber6's Avatar
This module was wired into the OBD plug. The sensor next to the OBD goes into some wires farther up the firewall. Is this thing lart of the aftermarket unit?
This was tucked under the carpet with some lights blinking
The OBD port has some wires that look modified
Not sure what is supposed to be here or not.
Old Sep 9, 2025 | 09:40 AM
this module was wired into the obd plug. The sensor next to the obd goes into some wires farther up the firewall. Is this thing lart of the aftermarket unit?
this was tucked under the carpet with some lights blinking
the obd port has some wires that look modified
not sure what is supposed to be here or not.
gps tracker
Old Sep 9, 2025 | 09:43 AM
gaber6's Avatar
Aftermarket or part of onstar? Aftermarket I presume
Old Sep 9, 2025 | 09:52 AM
AM installed for finance companies to disable vehicle when payments aren't made.
Old Sep 9, 2025 | 11:00 AM
aftermarket GPS locator they use to track and sell your data to data brokers as a side hustle. you might get a call from the dealer the vehicle was sold from.
but you can tell them to go eff themselves since now it belongs to you.
