2008 H3 TCM Transmission Control Module Issues
Old Aug 27, 2021 | 05:24 PM
Dtnations's Avatar
UPDATE - Got the PROGRAMMED TCM in and it worked like a champ. It fired right up and shifter works fine, took it for a test drive and so far so good. I will update in a few weeks or months to let everyone know if this corrected the transmission slipping issues - I sure hope it does.
Old Aug 27, 2021 | 05:37 PM
That was easy and cheap. Btw, I also recommend:
Old Aug 28, 2021 | 03:50 PM
Dtnations's Avatar
@hummerz I saw on a different post you wanted used ignition sensors. You want this one? It came off of a 2008 H3. The actual ignition is the new one in the box, I just took the sensor off and replaced it because I was having the pass lock issue. Here are a couple photos - let me know if you want them.
Old Aug 28, 2021 | 04:51 PM
I'm only interested in the switch. Let me know how much shipped to 44130.
Old Aug 28, 2021 | 05:05 PM
Dtnations's Avatar
You don't have to pay me anything. It's the least I could do for helping me with this TCM. Send me a message with name and address and I will send it your way. And thanks again for your help.
Old Aug 28, 2021 | 05:19 PM
Your settings don't allow messages. You are welcome.
Old Aug 28, 2021 | 06:05 PM
Dtnations's Avatar
Tried to figure out how to allow it and couldn't find it. My email is dtnations@msn.com if you want to email me.
Old Mar 19, 2024 | 11:41 AM
Droderick1's Avatar
Default Tcm
Vin programming required, did you give the seller your VIN? If not you only have a paperweight. Many available on Ebay offering programmed modules. Look here::::::::>>> PROGRAMMED Transmission Computer TCM ECU T42 24242391 24234503 24252114
link doesn’t work. Do you have a new link?
Old Mar 19, 2024 | 12:23 PM
So................ you dig up a 30 MONTH OLD Thread to tack on a question to demand the link maker get to updating the link so you don't have to use Google to find how to get a TCM programmed?
Not a great introduction to HF for your first Post. READ: Old Threads/'Necro-Bumping'
Old Mar 19, 2024 | 01:11 PM
Droderick1's Avatar
First of all, thank you for responding. Secondly, I didn’t demand anything, I simply asked a question. Thirdly, I was hoping to purchase a TCM already programmed, but was also surprised that could be done without the vehicle so I was intrigued how he does that.
Local dealer wanted to charge me 1hr/$209 to plug in the computer and diagnose/tell me it had a code the 700 code, which AutoZone did for free in 2 minutes. The dealer also charges $300 for the part that I can get at Napa for $180 and have the mobile guy charge me $300 to program, which takes 30 minutes max. I’m not cheap because I know the programmer costs money and the knowledge to program it, so o was just asking it an updated link was available to know my options.
The TCM takes less time to remove than it does to check oil on a dipstick.
Thank you again for the quick response.
CraigHenley
Mar 12, 2020 08:29 AM
Eric.sherrill
Nov 16, 2017 01:48 AM
Dave P.
Jun 7, 2016 12:02 AM
carolympus
Jul 12, 2011 02:42 AM
blueh2
Sep 28, 2010 05:53 PM
