2008 H3 Oil Change Message Reset
Old Jun 10, 2017 | 03:07 PM
robert49's Avatar
Default 2008 H3 Oil Change Message Reset
Changed the oil but can not get message to reset and A/C keeps cutting out since dealer did warranty work on switch. Any advice
Old Jun 10, 2017 | 08:41 PM
happythree's Avatar
i sometime need to mess with resetting to get it right.
dealer did work, dealer gets it back, kiss.
Old Jun 11, 2017 | 05:46 PM
robert49's Avatar
Found the info here thanks. Turn key to on, hold down trip counter and press accelerator pedal 3 times or until hear a beep. worked
Old Jun 12, 2017 | 11:24 AM
You do not need to touch the trip counter stick.
Old Jun 12, 2017 | 12:43 PM
It's all in the owners manual. If you do not have one you can download one directly from GM.
2006 H3
http://www.gm.ca/media/owners/manual...nual_en_CA.pdf
2007 H3
https://my.gm.com/content/dam/gmowne..._h3_owners.pdf
2008 H3
2009 H3/H3T
http://www.vadengmpp.com/owners-manu...Hummer-H3T.pdf
2010 H3/H3T
https://my.gm.com/content/dam/gmowne...h3t_owners.pdf
Old Jun 13, 2017 | 09:34 AM
650Hawk's Avatar
I've never tried the "accelerator pedal" method. From my '08 Owner's manual (just did it this weekend):
To reset the Engine Oil Life system:
1. With the engine off, turn the ignition to ON/RUN.
2. Press and release the stem in the lower center
of the instrument cluster until the OIL LIFE
message is displayed.
3. Once the alternating OIL LIFE and RESET
messages appear, press and hold the stem
until several beeps sound. This confirms that the oil
life system has been reset.
4. Turn the key to LOCK/OFF.
Didn't hear the beep, but it reset, so...
Old Jun 13, 2017 | 04:48 PM
happythree's Avatar
thats what i did. no beeps, did it again and it was ok. i was messing!!
rhill20
Jul 1, 2013 12:23 PM
Bo
16
Oct 9, 2010 08:44 PM
danist
Aug 6, 2007 02:32 PM
importkiller
Aug 4, 2007 09:19 PM
Rayvyn
Nov 27, 2005 02:10 PM
