2008 to 2009 exhaust manifold I5
Old Mar 29, 2022 | 08:06 PM
sycraft's Avatar
Default 2008 to 2009 exhaust manifold I5
The 2009 manifold is no longer available, but the 2008 one is. does anyone know if it is a direct fit. As far as I can tell, maybe just CARB certifying issues. I need to replace my 2009 manifold and do not want to go aftermarket.
Old Mar 30, 2022 | 11:23 AM
I cannot think of any reason an I5 exhaust manifold would not fit any year 2006-2010. I no longer have the 07, but I was going to go aftermarket if/when it ever cracked. You are correct though, a quick review shows different years for the same part.
I would have went with the MagnaFlow and called it done.
Good luck
Old Mar 30, 2022 | 09:05 PM
sycraft's Avatar
unfortunately I can get the OEM for 400$ less than the magnaflow....
Old Mar 30, 2022 | 09:25 PM
Mark R's Avatar
You can try this...https://www.partrequest.com/account/login
This is a Junk yard shopping service to put it another way... $3.99 charge for 48 Hour service or $6.99 for 24 hour service. They put out the part on their wire and yards from all across the Nation will respond if they have what you want. Of course these are used parts. Just like if you were going to the junkyard. Once you sign in you can go back to the page after you have logged in and you will see the yard that has your part with Phone number ETC. They don't send you emails so you have to go back and check and see if anyone has resounded. Just type in full description of what you want and the quality level..
I just located my H2's new Climate control module thru them for an 2009 H2.
Old Mar 31, 2022 | 06:32 AM
atvspeed4's Avatar
2009 is different than 2008 there is a different flange at the bottom that accommodates additional mounting. For my 2009 I found an ebay stainless manifold/ cat for like $180 that was perfect fit and no issues.
Old Mar 31, 2022 | 09:18 AM
Thank you for that. Interesting that there is a difference and that explains the different part call outs for different years.
Old Mar 31, 2022 | 01:56 PM
CAR-PART does the same thing for free
Old Mar 31, 2022 | 05:07 PM
Mark R's Avatar
Good to Know... Thanks for the info.. Could have saved $4.00..L.O.L.
Gdraft
Aug 7, 2024 01:05 PM
rconkin
Feb 16, 2021 03:35 PM
Gdraft
May 6, 2020 08:24 AM
struhmalong
Jan 19, 2015 04:34 PM
MisterMark
23
Jun 27, 2008 08:20 PM
