2007 H3 ignition cylinder and door lock question.
Old Aug 29, 2024 | 04:26 PM
waltham41's Avatar
Default 2007 H3 ignition cylinder and door lock question.
My 2007 H3 is giving me a lot of trouble with the ignition cylinder.
I've decided to change it out and replace the door lock also to keep the vehicle with one key.
The prices for a H3 cylinder and door locks on fleabay are expensive
I noticed the online pictures of the parts look very similar to a 2007 chevy colorado which is MUCH cheaper than the hummer parts. Does anyone know of they will interchange?
thanks
Old Sep 3, 2024 | 09:45 AM
To replace the ignition switch your key does not need to be changed. The lock cylinder and switch are separate parts. I have never seen a bad lock cylinder on an H3, but plenty of ignition switches have worn out.
No the parts do not interchange, look at the part #s.
Old Sep 3, 2024 | 03:08 PM
waltham41's Avatar
Sorry I should have been more clear. The cylinder/key is whats giving me trouble. AFAIK the replacement cylinder cannot be mated to the existing key.
thanks for confirming that the colorado parts will not interchange.
Old Sep 3, 2024 | 03:48 PM
https://www.autozone.com/interior/ig...360/743225_0_0
you can key it to your existing key.
Old Sep 3, 2024 | 08:18 PM
waltham41's Avatar
i.. did... not... know this was possible! You just saved me a lot of work friend.
Thank you very much 😀
pigskinzen
Jul 6, 2022 12:21 PM
finall
Jul 5, 2021 11:37 AM
Charles Federico
Feb 20, 2020 02:12 PM
Eric Mitchell
Jun 18, 2018 11:25 AM
mpac165
Jun 8, 2016 10:38 AM
