2006 monsoon amp watts?
Old May 26, 2020 | 01:43 PM
Bulldogpaysme's Avatar
Default 2006 monsoon amp watts?
Can anyone find the watts on the factory amp? I can only find the part number. Thank you for Any help
Old May 26, 2020 | 02:57 PM
FUSE x VOLTAGE (12-14.5v) x EFFICIENCY (0.6 for class A/B amps)
Old May 27, 2020 | 07:05 AM
The "actual" power I believe is around 480 to 500 watts RMS with 14V @ 4ohm.
Approx. 25w to the front tweets @ 4ohm (passive crossover)
Approx. 35w to each door @ 4ohm
Approx. 75w to each voice coil of the subwoofer (dual 2ohm sub). So they will receive approx. 125w to 150w due to the 2ohm load the amplifier sees.
Old May 27, 2020 | 01:34 PM
I saw somewhere???? the Monsoon System is 500 watts peak and 240 RMS per GM.
Split 120 4ohms to the doors and tweeters and 120 to the sub which is a dual voice coil at 2ohms each coil.
I know the stock tweeters use an integrated high pass crossover.
Old May 27, 2020 | 02:20 PM
Not sure what amp you guys are referring to? Oem for the H3 is;;> 15086821 & 15851584
Root means square(RMS) refers to how much continuous power an amplifier can output
Fuse #38 is 25a, capable of 350 watts @14v and fuses are always overrated!
I've listened to my stereo full volume many times while driving@14.5v, and parked, resting voltage @12.5v, and never blew the fuse, all speakers/sub oem, still working and sound great.
Down to earth, 25(amps) x14 (volts) x.6(efficiency)=210 RMS
Btw, there are many sites that refer to gm's oem amp(late '90's to today) @ 200w rms.
Old May 27, 2020 | 07:21 PM
Since you have the part number, make a call for the exact specs here:::> Bose
Old May 28, 2020 | 01:16 PM
Monsoon amps are Class D, not A/B.
Monsoon is NOT BOSE.
Old May 28, 2020 | 02:41 PM
I can't find a Sonigistix Corporation customer service number.
smileitzvincent
Aug 20, 2013 12:19 PM
luxx989
Jan 8, 2013 02:03 AM
NoThreePutts
Aug 31, 2011 07:49 PM
orazids
Jun 16, 2009 09:20 PM
H3toy
May 30, 2007 09:31 PM
