2006 hummer h3 transfer case gear grinding noise
Old Mar 29, 2023 | 02:32 AM
Rocky79's Avatar
Default 2006 hummer h3 transfer case gear grinding noise
Need help i have a 2006 hummer h3 with 5 cyl engine base package 110000 miles on it when i accelirate fast and uphill makes gear grinding noise like clack clack clack then goes away seams like its coming from the transfer case please help diagnostic
Old Mar 29, 2023 | 10:03 AM
When was the last time you changed the Transfer Case fluid, front diff lube, rear diff lube? Your description, may we assume you are driving on pavement if Hi and not on Hi Lock?
Old Mar 29, 2023 | 06:01 PM
Justinh's Avatar
I wouldn't call a "clack" a grinding noise. Uphill - what kind of angle does it take to do this?
Are all the front axle bushings good?
Old Mar 29, 2023 | 08:04 PM
If you hear a "clack-clack" kind of rattle it could be a sign of piston slap.
Old Mar 30, 2023 | 09:35 AM
I have personally seen an 06 do that when under load wheeling uphill........... the clack clack clack thing.
Owner suspected worn out T Case chain, too slack and skipping. If I remember right, it was the old plastic T Case Fork not holding lock 100%. Could still happen on pavement if popping in/out of lock or close enough to make the racket?
Old Mar 30, 2023 | 05:05 PM
How did you SEE a "clack clack clack thing"?
Old Mar 31, 2023 | 09:58 AM
Poor choice of words....... "observed" as in saw it for myself. That would be use of the eyes while the event was occurring to note that the 06 H3 was under load climbing a hill and use of my hearing to discern the clack clack clack thing at that time.
Old Mar 31, 2023 | 06:30 PM
Yet, under a load, you could get a piston slap: "clack clack clack thing". OP needs to check where the noise is coming from!
cjmsports
Mar 1, 2019 06:37 AM
user 956363738
Jan 18, 2016 02:27 PM
kicklol
Oct 16, 2015 03:07 PM
telemike
Nov 13, 2012 09:41 AM
djadds
Sep 25, 2012 07:45 AM
