2006 H3 4wd stuck in 4hi lock
Hey guys I have searched on here and from what I have seen when the 4wd gets stuck in hi or low it will not change, mine is stuck in 4hi lock but can push the button and it will go into 4lo lock, transfer case electric motor seems to be working as it should when removed, could this be the notorious plastic shift fork? Thanks
When my truck had a similar problem.
Dirty contacts on the switch was the problem from not much use.
My simple and lucky solution was to operate the buttons frequently and the trouble cleared..
Carbon build up was evidently the problem.
I took the switch apart and sprayed it well with electronic cleaner and reinstalled this morning with no change, still in 4hi lock, tried backing down the driveway and pushing the button from 4hi to 4hi lock several times with no change at all
mine got stuck in 4low and i was racking my brain trying to figure out what was wrong, turns out it was just the 4lo button that was sticking and wouldn't 'pop' back out after pressing it, a little cleaning and all was good.
Alright an update, had a transmission shop replace the fork with a new metal one and anything is they could find with it, turns out the plastic one was wore out and also a bearing, put back in with no change, the mechanic who also does transfer cases suspects an electrical issue so it now is at one of the best guys in the area for auto electric
WR3NCHE4D
Oct 13, 2018 03:05 PM
flyday58
Feb 15, 2016 01:39 PM
