07 H3 rear window washer.
New to me vehicle. 1st H3. Does the rear washer draw its fluid off of the front reservoir, and is the washer pump built into the rear wiper motor?the wiper works but no Washer so I'm trying to get an idea of where to start troubleshooting.thanks!
I found out the hard way that my problem was a separated hose on top of the rear wheel well. The hose runs from the engine bay, down along the rocker panels inside the cab, then up and over the rear drivers wheel well. I completely soaked the back insulation before I realized I had a break in the hose instead of a pump issue.
Fill the reservoir, have assistant press the rear washer button, listen for the pump (no pump noise it's the pump or fuse 16 if I remember correctly).
Pump is good follow the line in the engine compartment and look for leaks (split line).
Remove the rear cargo door cover and see if it is leaking inside there before tearing the interior apart.
820larry
Aug 19, 2012 10:14 PM
Mountain Trooper
May 25, 2008 10:18 PM
