06 H3 multiple problems
1. wipers on all the time.
2. headlights won't come on.
3. engine only run with light switch in park position.
Have tried: new BCM. new multi function switch replacement. new ignition switch. new light panel. no help.
If that is wet or the harness is frayed/compromised, the BCM is not reading what is actually happening.
After you start the truck and turn the head light switch to a different position, does it turn off?
I had this problem after the electrician messed up the wiring trying to find a switched power source for an aftermarket fan relay.
It could be anywhere depending on where the line is tapped (under the dash or inside the engine bay).
Try following those wires to find where they were tapped. If you have aftermarket accessories, try disconnecting them at their relays and power sources and see if it makes a difference.
Calgary
07-31-2010 11:29 PM
anthony42376
35
02-01-2010 07:40 PM
OffRoadin
33
10-30-2008 06:23 AM
Alan06SUT
05-11-2007 10:46 AM
