06 H3 multiple problems
Old Apr 16, 2018 | 12:41 PM
smokewatts's Avatar
Default 06 H3 multiple problems
1. wipers on all the time.
2. headlights won't come on.
3. engine only run with light switch in park position.
Have tried: new BCM. new multi function switch replacement. new ignition switch. new light panel. no help.
Old Apr 17, 2018 | 12:30 PM
Did you dry out the BCM at the harness connection before swapping in a replacement? Give it a good inspection under bright light.
If that is wet or the harness is frayed/compromised, the BCM is not reading what is actually happening.
Old Apr 17, 2018 | 02:54 PM
amrg's Avatar
After you start the truck and turn the head light switch to a different position, does it turn off?
I had this problem after the electrician messed up the wiring trying to find a switched power source for an aftermarket fan relay.
Old Apr 17, 2018 | 07:21 PM
smokewatts's Avatar
Yes, the engine shuts off in any position except parking lights.
Where was the wiring problem located?
Old Apr 19, 2018 | 04:32 AM
amrg's Avatar
It could be anywhere depending on where the line is tapped (under the dash or inside the engine bay).
Try following those wires to find where they were tapped. If you have aftermarket accessories, try disconnecting them at their relays and power sources and see if it makes a difference.
Calgary
Jul 31, 2010 11:29 PM
anthony42376
35
Feb 1, 2010 07:40 PM
OffRoadin
33
Oct 30, 2008 06:23 AM
OffRoadin
Nov 12, 2007 07:59 PM
Alan06SUT
May 11, 2007 10:46 AM
