nid gate window won't go down
mission accomplished!!
ran a new wire with a 25 amp fuse from a constant 12 volt pin on the circuit box. Ran it to the back and connected to both orange wires going into the midgate motor plug.
pulled the old 25amp midgate fuse from the circuit box so that wherever the break was in the original doesn't effect anything.
All is working as it should, and now I can put down my midgate.
Thank you for your help.
now off to the next project
So the mid gate window in my 2008 SUT will not go down. I checked and replaced the fuse in the drivers compartment, and that's not the issue. The mod gate window, and the all down window switches won't bring it down, although the all down window button works for all other windows. I have removed the midget panel, to ensure the gate is fully closed, and that's not the problem.
are there any other fuses, perhaps in the midget itself, or any other ideas to try?
- where can I buy a midgate window motor fir my 2005 H-2SUT ??
Im having this problem in reverse. I cant get my rear window back up. Can you tell me where this fuse box is located?
if you still can’t get the window up, try closing the mid gate again to insure it is closed firmly. I usually have to close mine a couple of times to get the window go back up after opening the mid gate.
Dviper27
May 25, 2013 03:46 PM
