Hummer H2 SUT For some who need the usefulness of a truck, but do not want to compromise the Hummer look, the H2 SUT does just that.
Front airbag impact sensors
Old Jan 14, 2025 | 04:11 PM
Derek4reaL's Avatar
Default Front airbag impact sensors
Does anyone know if I can use a earlier model GM airbag sensor on my 2005 hummer H2 SUT the part number for the 2005 model is 10370148. Is there any other compatible sensor on the market?
Old Jan 14, 2025 | 05:50 PM
What's the issue with your sensor?
Old Jan 14, 2025 | 09:20 PM
Derek4reaL's Avatar
The airbag sensor has gone bad setting off a code showing service airbag. There are no available sensors to be found for that year at any auto parts store. Have you heard of anyone using an early model airbag sensor thats still being manufactured like for an escalade or something similar with a 6.0 liter 364 cu in
Old Feb 14, 2025 | 12:24 AM
bkmatheis's Avatar
Default Following
I have a 2006 with the exact same need. I can’t find a sensor anywhere and I’ve been stalking the GM as well as the Dorman variant with no luck. It seems there has got to be a version of these sensors that should work but I can’t find anyone that knows.
Old Feb 14, 2025 | 09:41 AM
if you have a pick n pull near you that might be the simplest way to find out. get a variety of them and start testing. closest might be GMT-800 family or 900 family depending. but not necesserilly.
Old Feb 14, 2025 | 02:49 PM
bkmatheis's Avatar
I have a couple salvage yards around me here but unfortunately none have an 06 on hand.
Old Feb 15, 2025 | 11:03 PM
03-07 should be fine i am not sure for 08-10 but maybe possible
Old Feb 16, 2025 | 12:39 AM
bkmatheis's Avatar
You sure brother? Since starting this search, I’ve had several people tell me the 03-04 are one part number, the 06-07 are a different part number and the 08-09 are yet another and none of the three can be swapped for the other. None of those people seemed REALLY sure of their statements (even the dealership parts guy) though so I still don’t know.
Old Feb 16, 2025 | 09:12 AM
Old Feb 16, 2025 | 07:28 PM
the part number got superseded by newer part numbers as the years progressed.
Mike2008
Jan 8, 2025 12:41 PM
Bgoforth
Dec 11, 2020 09:12 PM
myrddin
Jan 7, 2019 01:08 PM
Micheletti
Apr 24, 2013 02:26 PM
alex2mil
16
May 21, 2008 06:40 PM
