Hummer H2 SUT For some who need the usefulness of a truck, but do not want to compromise the Hummer look, the H2 SUT does just that.
2007 H2 SUT tailight out but brake and turn work
Old Mar 17, 2022 | 01:12 PM
Stace723's Avatar
Default 2007 H2 SUT tailight out but brake and turn work
Help please I looked through all previous threads with no solution.. left tail light no workSame bulb for brake turn signal work fine same with taillight in bumper and yes left rear side marker I'd put too, I have checked everything, any help here please...
Old Mar 18, 2022 | 01:57 PM
Sam!'s Avatar
Have you replaced the bulb itself, as it sounds like that is the problem the Parking (tail) light portion of the same bulb could be out and the Brake and Turn light would still work.
Old Mar 18, 2022 | 05:21 PM
Stace723's Avatar
Yes absolutely that was of course my first move and when one is out I replace both right and left so all are new, I have traced the ground thinking it was that, I disconnected cleaned and sanded area for good connection and not that either, I traced all wiring to the connection block, disconnected removed the circuit board cleaned and all looks good, I even switched bulbs from left to right etc and no it's a left issue, my next move is to check voltage at connections but was hoping someone has been down this road and could offer advice . Thanks
Old Mar 18, 2022 | 05:45 PM
Clean/May need to replace the socket!
Old Mar 20, 2022 | 09:54 AM
Sam!'s Avatar
How about testing with test light the plug end of the tail lights harness or switching the harness from right to left to test.
mrmseto
Dec 16, 2024 02:31 PM
PINETAR1968
Oct 6, 2016 07:51 AM
JonnyD
Aug 6, 2013 05:12 PM
H3tacticalguy84
Jul 20, 2011 09:44 PM
GarrettMoore
Nov 24, 2008 12:03 PM
