Hummer H2 SUT For some who need the usefulness of a truck, but do not want to compromise the Hummer look, the H2 SUT does just that.
2007 H2 sut, Stalls at idle /Take off, hard to restart
Old Jul 31, 2022 | 08:43 PM
$tace723's Avatar
Default 2007 H2 sut, Stalls at idle /Take off, hard to restart
Very frustrated, got a 2007 Hummer H2 SUT, its a great truck, a tank for sure and to me worth every dime I spent, I live in Texas so its in great shape not being exposed to harsh weather, its my daily driver and other than routine maintenance it has not been an issue but now its an everyday problem I just don't know when its going to begin, Could start fine, run fine or Could start fine, cold or hot it will idle fine at about 500 rpm, then will miss and stall, stalls at idle/ take off from lights & stop signs and its very Hard to restart, I have to hold pedal to floor and after much cranking it will start, sometimes it will catch, idle like sh*t for a sec or two then die again, as I continue to restart it eventually it will start and at least stay alive, most times to avoid issue at lights or stops ill hold pedal to idle at about 1000rpm in neutral then shift to drive and most times that works, sometimes when it starts to idle rough I can keep alive by holding gas pedal to a high idle and other times that doesn't work it stalls....this is all with no check engine light and no codes on scanner??? very frustrated, in last 12 months I have replaced fuel pump, plugs, wires, ignition switch, mass air flow, an O2 sensor, cleaned throttle body, and replaced oil pressure sending unit and its filter screen. it was recently throwing transmission codes P2761, P0740, P0753, P0758, P0785 but thanks to this forum got that resolved, all of those codes was due to bad ignition switch and I replaced it and that solved all those codes and check engine light turned off..
does anyone have an ideas?? timing issue? hard to believe it runs this way aand no check engine light... please help.
Old Jul 31, 2022 | 10:45 PM
H2-SUT's Avatar
Sounds like it could be the the Crankshaft position sensor or connector issue...
Old Jul 31, 2022 | 10:52 PM
check your intake for air leaks. if you have a scanner with live data look at the maf reading and also look at your long and short fuel trim readings.
Old Jul 31, 2022 | 11:47 PM
$tace723's Avatar
Will do in AM Thanks, Ill report back what I get
Old Jul 31, 2022 | 11:49 PM
$tace723's Avatar
cam position sensor? might be.. ill check it out and report..
Old Aug 1, 2022 | 10:14 AM
2004H2's Avatar
Default Sea-Foam
Hi, ours started acting up, so i put in 2 cans of sea- foam in the gas tank, and about 30 miles later it was running like new again, so evey month i add a can of sea-foam in both h2/h3 have had no running/starting issues after that…..
Old Aug 1, 2022 | 05:15 PM
calif phil's Avatar
Have you had a crankshaft relearn done? That is what I would suggest as the next step.
Twisted sisal
Sep 4, 2019 03:40 PM
Charles Coutts
Jan 21, 2016 08:20 AM
Justinh
Jan 9, 2016 11:18 AM
KentuckyRock
May 16, 2013 07:47 PM
branstone
20
Mar 26, 2012 06:12 AM
