Wire use?
Old Mar 22, 2023 | 01:09 PM
PGI Conch's Avatar
Default Wire use?
Anyone know what the purple wire/connector coming out from the Fuse Box goes to?
Old Mar 22, 2023 | 04:57 PM
Looks AM to me. You can trace it, or cut it and see what happens.
Old Mar 22, 2023 | 05:30 PM
PGI Conch's Avatar
Perhaps, but there arent any aftermarket items on the vehicle except PO changed out the wheels for some AM wheels (one of the reasons we purchased this one, neither PO's "personalized" it with add ons). The plastic wire protector was coming out of that area before the dealer replaced the entire fuse block with a new GM product. Now that wire/connector are more apparent than just seeing the plastic protector. Just thought someone may be familiar with it before I go pulling the shroud off to see why the dealership didn't ensure it was put back and attached properly.
Old Mar 22, 2023 | 06:15 PM
OEM wiring is solid color or with a straight line tracer(different color stripe on the wire). That wire appears to have a spiral tracer(purple with black) and also appears damaged/separated internally.
OEM wiring with tracers:
Your Wire:
Old Mar 22, 2023 | 06:32 PM
PGI Conch's Avatar
Your Wire:
Gotcha. I will be finding the solution sometime in the next week or so when I pull the cover.
Old Mar 22, 2023 | 06:40 PM
Just trace where the wire goes. Could be for a tracking device?
blackdragon
Feb 9, 2011 03:21 PM
wet_rat
Jul 8, 2010 09:52 PM
motley1987
Mar 13, 2010 03:25 AM
HummerGuy
17
Oct 5, 2006 05:36 PM
LostOne
Feb 28, 2006 09:56 AM
