When can I use 4 hi lock
Old Jan 16, 2020 | 05:18 PM
apollo18's Avatar
Default When can I use 4 hi lock
Got a 2003 hummer h2 and here in alberta it’s super snowy and the temperature is -40. The roads are only partially clean, some places will be relatively dry and some will have an inch of ice/snow caked on. 4 hi was been fine but I was wondering if I could use 4 hi lock. I read something about there needs to be a little bit of slip and I noticed when I drove into a parkade it was acting differently during turning so I went back to 4 hi. So can I use 4 hi lock without any troubles as long as I’m not driving on the highway or full dry pavement? Or is it only supposed to be used off-roading or when I’m stuck?
thanks
Old Jan 16, 2020 | 05:58 PM
thanks
If you have a "slip" on 1" of snow, GET NEW TIRES!
Old Jan 16, 2020 | 07:12 PM
apollo18's Avatar
Ahah yeah the tires are actually brand new, I know that there’s tons of ice in some places and that’s what basically makes the truck slip. So I was wondering if I could just daily drive in 4 lock
Old Jan 16, 2020 | 07:32 PM
eh? I've replaced my "actually brand new" tires multiple times @ no charge, over the years(mfg concession). I now have the tires to drive on with confidence, I can drive through 2ft of snow without a problem, and never needed to use the lockers.
Btw, nothing will help you on ice.
Old Jan 16, 2020 | 07:49 PM
firmani99's Avatar
What tires do you run now?
Old Jan 16, 2020 | 08:01 PM
Grabber AT2
Even for a more aggressively designed tread, the tire runs exceptionally quiet. In addition, it makes an excellent tire for snow and ice. The biting edges of the tire produce excellent traction on snow, and grip tight on icy roads.
Old Apr 15, 2020 | 10:54 PM
Rusty_03's Avatar
I have an ‘03 H2 and I live in New England. I don’t have any problems in the winter. . . . Unless it snows 12”+ while I’m out. Then getting UP my drive is a PITA! It’s very steep and paved. These wide tires are like snowshoes. They don’t pack all the way through. Wife has done 2 180’s and wound up back out in the street!
If you could TURN OFF T/C then it would be great. As soon as you can get a tire spinning, it puts on the brake for that wheel! However, after watching a couple of DMax conversions, I’m thinking about putting a switch in that will disable T/C, allowing you to be able to spin the tires to clear the treds and dig down. Much cheaper than a front locker.
MikeH
Old Apr 16, 2020 | 09:05 AM
legerwn's Avatar
Yes you can and that is exactly what it is designed for, semi-slick conditions as snow, boat launches, etc........
Rusty_03 are you engaging the TC2 function which will allow more wheel spin prior to the TC taking control?
Neal
NCH2
Feb 28, 2015 08:24 AM
Poconosteve
Mar 12, 2014 07:31 PM
happythree
Mar 9, 2013 06:27 PM
K0PIR
Feb 18, 2012 10:35 AM
gotafish
Jan 21, 2012 01:15 PM
