Turbo vs Supercharger
Old Jun 7, 2022 | 05:29 PM
DELTA's Avatar
Default Turbo vs Supercharger
Hello everyone, I am looking to put some performance parts on my 04 H2. I have been contemplating putting twin turbos on my truck while I'm upgrading my exhaust. I have looked at a few supercharger kits as well. What have or would you guys go with and why? Thanks.
Old Jun 8, 2022 | 07:41 AM
calif phil's Avatar
There are quality bolt on supercharger kits made for your truck, is there a turbo kit available with a track record, or is it a homemade kit from Joe's turbo emporium and bait shop?
Don't get me wrong, I love turbos and used to be in that business years ago. I have seen some horrible turbo setups. Done right, both should get you the performance you desire.
Old Jun 8, 2022 | 10:30 AM
Main point I'd consider is that a supercharger is generally able to make and add power at a much lower RPM. So if you are building up you H2 into a race truck where you want power when it is wide open at 3000+ RPM then a turbo would be an excellent option. If you are wanting power across a much broader range of RPM's then I'd argue that a supercharger would be the better option.
Then you can get into the roots type versus centrifugal type superchargers.... each has their own pros and cons and those who will argue for each type.
Old Jun 9, 2022 | 02:43 PM
DELTA's Avatar
Thanks for the advice. Will a supercharger damage my transmission? I am using my hummer for work and it's doing a great job for its designated function. I am not a mechanic so I would hate to do something to my truck that I couldn't fix.
Old Jun 9, 2022 | 07:30 PM
at 18 years old i would be pretty sure the tranny will fail sooner if not the transfer case.how fast do you really want to sling 9000 pounds around?
Old Dec 24, 2022 | 01:50 PM
C57's Avatar
C57
Default 9000#
[QUOTE=bronxteck;394202]at 18 years old i would be pretty sure the tranny will fail sooner if not the transfer case.how fast do you really want to sling 9000 pounds around?[/QUO
How does someone gather a 9000# H2. Did the weight go down when they made my 08 H2. I keep hearing weights from 4 something thousand to now 9000. I just am confused now. Thanks if you can clear this up.
Old Dec 24, 2022 | 04:16 PM
2008 HUMMER H2
Curb weight 6,614 lbs
Gross weight 8,600 lbs+(depends on payload)
Maximum towing capacity 8,200 lbs.
Old Dec 24, 2022 | 09:35 PM
C57's Avatar
C57
2008 HUMMER H2
What's the difference between curb and gross? I know what gross means. Lol, you know what i mean. Thanks.
Old Dec 25, 2022 | 10:18 AM
Curb weight is the actual weight off the assembly line without payload(passengers, cargo, add on accessories, etc)
Gross weight= CURB WEIGHT + PAYLOAD.
Old Dec 25, 2022 | 04:07 PM
finall's Avatar
Not sure how that would drive at 8600 lb. I was at 8000 lb and the thing is as slow as a slug.
Funny, mileage did not change on the 600 mile circuit with the load.
