Transmission Slipping
Old Feb 24, 2021 | 02:16 PM
2005H2's Avatar
Default Transmission Slipping
Rig has 164k on it. Slips and revs high at times. Is it worth spending $400 on a full flush or should I save that money and get the transmission serviced and or replaced? I've added Transtune btw and it didn't change anything.
Thanks in advance.
Old Feb 24, 2021 | 03:28 PM
There's your problem, the odometer is running backwards.
Originally Posted by 2005H2
I believe my transmission is slipping, I've noticed it the last few months. Engine seems to rev higher when pressing the accelerator but car does not respond.
The rig has 165k on it and is not driven very much.
How long do I have before it outright fails?
Do I need a brand new transmission or would a repair do the trick?
Also, should I fix before I attempted to sell it? Or leave as is (if I chose to sell it).
I'd love your guys' advice, never had any transmission problems with any of my vehicles before, this is my first.
Old Feb 24, 2021 | 03:47 PM
Sirina2's Avatar
My 2005Lux had same thing at 123k. Lost 2nd gear. Drove it to transmission shop. Cost me around $2000.00 That included them replacing the transmission cooler lines also because they were rusty and would not last much longer. Good Luck from WV.
Old Feb 24, 2021 | 03:56 PM
Old Feb 24, 2021 | 04:47 PM
2005H2's Avatar
A new transmission is $4k out here. I'm wondering if should sell it. Would you sell it or fix then sell?
Old Feb 24, 2021 | 04:50 PM
How much do you want for it?
Old Feb 24, 2021 | 08:44 PM
2005H2's Avatar
I'd list it for 8k
Old Feb 25, 2021 | 08:05 AM
calif phil's Avatar
Don't waste your money on a flush. Time for a Caitlyn Jenner.
Old Feb 25, 2021 | 10:32 AM
fastNYsix's Avatar
Where are you located? I would agree that a flush would probably make it worse.
Old Feb 25, 2021 | 02:07 PM
Daniel Z's Avatar
For what it’s worth I installed a used transmission with 70k miles on it for around $1600. If not doing that much driving may be something to look at to save cost. Have you had the thing scanned? Codes? I had a very similar situation but only needed to replace some type of a module (solenoid?) as my truck was stuck on second or third gear can’t remember that was years ago. Very cheap to fix at that time.
the 05 are good year models. Good luck
