transfer case not shifting to 4low/high
Old May 13, 2024 | 07:06 PM
HandsomeSteve's Avatar
Default transfer case not shifting to 4low/high
07 H2 transfer case not shifting to 4low/high. since she's stuck in normal 4wheel drive will driving like this create damage to transfer case or transmission?thanks
Old May 13, 2024 | 07:40 PM
check the connector at the transfercase maybe it is loose or has corrosion also the switch might need cleaning.
Old May 14, 2024 | 08:26 AM
dontheo55's Avatar
There is also a transfer case motor which can go bad. I am on my third. Not to expensive a fix either. No damage should occur with it no shifting into 4H or 4L. .
Old May 15, 2024 | 09:14 AM
excellent advice as usual, I will check the encoder motor connection. from my research on this none shifting issue on 2500 trucks there's suposed to be a group of ground wires located under body just under the driver seat there's high proability they are corroded an cleaning them fixs the none shift issue. I looked but couldn't see them.
IIRC this group of ground wires on the H2 is located around the driver side front bumper I looked there to didn't see. a image of these grounds would be a big help.
my main concern was will driving the H2 when she's stuck in the normal street driven 4wheel drive would cause more damage?
here's wheres she's stuck.
I have also tryed cycleing the button w/ engine running transmission in nuetral depressing the 4/low an 4/high all I observe is yellow blinking Light I've depressed these buttons over 100 time in hope of loosening up the switch.
I'll check the encoder wiring an report back.
can I test the wiring at the encoder motor. like test it in regular 4x4 then retest w/ 4/low button depressed? like will there be zero VDC while in regular 4x4 an 5VDC when pressing the 4/low an which wire is the buttons signal wire?
thanks again bronxteck
excellent thats what I was concerned w/ causing more damage. bc I'm not a off roader I'm a on roader.
are buying the el cheapo encoder motors for $50. or the expensive ones for over $200.?
hoping to drive the H2 a bit this summer. thanks dontheo55
Old May 15, 2024 | 02:03 PM
T L
Mar 12, 2022 01:03 PM
KpH2HUMMERSUT
Jan 17, 2022 12:10 PM
KpH2HUMMERSUT
Jan 15, 2022 04:55 PM
Donnie6983
Nov 19, 2017 12:11 AM
FatJay
Apr 20, 2017 06:36 AM
