Torque converter info plz
Hey guys I'm in the middle of my tranny rebuild and I need some information quick. I Don't know whether or not to change out my Torque converter. If I do what RPM stall should I put on it. It's stock right now at 175k with 37" tires. I plan on putting a small lift and maybe some small engine mods with the next few months. (Later on a supercharger, but not for a few years.) any information could help. It's my first rebuild thanks guys.
frankly i wouldn't put a high stall in, like 2400- 3000 rpm or even higher, because you would need to acheive 2400-3000 rpm everytime you pull out, stop signs... stop lights... stuck in traffic... but if you do decide thats what you want, make sure you add a bigger tranny cooler, fluid temperature will increase the higher u go.
- About 2 hours for the breakdown.
- Another 3 hours for the assembly so far (only about 2/3 I had to stop because they forgot to send me a friction plate)
I had to stop because I realized I had a bad reverse input drum. So I have to wait till the extra parts come in to finish it.
If you are planning to supercharge for sure later make sure to keep that in mind when you make your final decision to select a stall converter. The extra power/torque of the charger will have your converter flash higher. I personally don't think that running a higher stall converter on a heavy rig like this is a good idea, a lot of driveline parts that will see extra stress and if you tow there is going to be a lot of additional heat build up.
