Tired of the oil leaks
Old May 17, 2020 | 04:24 PM
tharber's Avatar
Default Tired of the oil leaks
So my H2 has had a drip here and a drip there for some time. I finally tracked it down to the oil cooler lines and a valve cover gasket. So today I installed a oil cooler block off plate and new valve cover gaskets. I added a little color while I was at it. I was extremely happy with how clean the valve train is after 170,000 plus miles.
Old May 17, 2020 | 07:32 PM
legerwn's Avatar
looks good, that is clean, what oil do you use?
Old May 17, 2020 | 08:05 PM
iwillnc's Avatar
I feel fairly confident that my oil cooler port is leaking as well, why did you block it off instead of replacing gasket/lines.
Old May 17, 2020 | 09:34 PM
are you missing manifold bolt towards the firewall?
Old May 18, 2020 | 06:58 AM
tharber's Avatar
99.9999% Mobile 1 synthetic on all oil changes and maybe once a year a half container of Marvel Mystery Oil for a few miles before oil change.
Tim
Old May 18, 2020 | 07:07 AM
tharber's Avatar
A few reasons. The block off plate was a whopping $18, so it was the easiest way to find out if my leak was indeed coming from the oil cooler lines. New lines are upwards of $120 and a pain in the *** to get to for replacement. All I did was disconnect the connection block and threw in the new plate, I left the lines in place for now. I also would have wanted to change over to lines from a newer Hummer with electric fans as I just tried to convert mine but failed because the 2005 lines do not offer the clearance needed for electric fans. I also don't know that an oil cooler is an absolute necessity. These Gen III engines are some of the only LS engines with an external oil cooler so I didn't think it would hurt. My overall temps are really low as it is from the new 3 core radiator. I will probably put new lines on it when and if I go with headers but that's another project.
Tim
tharber's Avatar
Don't think so. I put new knock sensor in it a few years back and had no issues. What are you seeing?
Tim
Old May 18, 2020 | 09:33 AM
iwillnc's Avatar
I think he meant exhaust manifold bolts which don’t need to be removed for the knock sensors. From the picture your rear most exhaust manifold head seems to be missing.
Old May 18, 2020 | 10:29 AM
tharber's Avatar
Yes I have a few broken exhaust bolts. I'll get into t hat another day.
Tim
Old May 18, 2020 | 10:31 AM
calif phil's Avatar
If mine oil lines were bad I would block them off, I don't have the need for the cooler anymore. I love the orange valve covers.
