Tired of the oil leaks
So my H2 has had a drip here and a drip there for some time. I finally tracked it down to the oil cooler lines and a valve cover gasket. So today I installed a oil cooler block off plate and new valve cover gaskets. I added a little color while I was at it. I was extremely happy with how clean the valve train is after 170,000 plus miles.
https://cimg9.ibsrv.net/gimg/www.hum...388b35df03.jpg https://cimg0.ibsrv.net/gimg/www.hum...161ee6b091.jpg https://cimg1.ibsrv.net/gimg/www.hum...b0fb6e4c35.jpg |
looks good, that is clean, what oil do you use?
I feel fairly confident that my oil cooler port is leaking as well, why did you block it off instead of replacing gasket/lines.
are you missing manifold bolt towards the firewall?
Originally Posted by legerwn
(Post 373182)
Tim |
Originally Posted by iwillnc
(Post 373184)
Tim |
(Post 373187)
Tim |
I think he meant exhaust manifold bolts which don’t need to be removed for the knock sensors. From the picture your rear most exhaust manifold head seems to be missing.
Yes I have a few broken exhaust bolts. I'll get into t hat another day.
Tim |
If mine oil lines were bad I would block them off, I don't have the need for the cooler anymore. I love the orange valve covers.
