Tc and abs lights
Old Oct 3, 2024 | 12:58 PM
Tatman54's Avatar
Default Tc and abs lights
Hey all I did some searching but I am having an odd issue. My 03 H2 has 110k mi and there were absolutely no lights on dash except for my dimly lit brake light. My H2 Had original rotors so last weekend I changed front rotors and pads. I made sure to remove excess brake fluid as I knew that pushing calipers back would cause over filling. But now I get abs and tc lights with 3 dings. Had 0 issues with speed sensors before hand and when lights are on I pull codes and I have 0 faults on scanner. so I am getting abs and tc lights with no fault being stored. Kind of at a loss here as nothing changed except for rotors and pads. Hope someone has an insight as I ordered speed sensors just in case..
Old Oct 11, 2024 | 03:18 PM
RobertDez's Avatar
TC light is on because there's an error in the ABS system. First thing to check is the sensors. If you look on the inside of your front tires, follow the wire that comes out the front hub to a connector check to make sure it's connected. A bidirectional scanner or a tech 2 device is useful in diagnosing this stuff.
Old Oct 11, 2024 | 05:38 PM
Use a scanner with ABS capability scan ABS then post the code(s).
Clydeyb
Feb 6, 2023 10:40 PM
awdavis214
Jul 27, 2022 12:46 PM
H32006
Dec 6, 2019 07:15 PM
Crash Gear
Sep 22, 2013 04:51 PM
19tony56
Sep 27, 2012 08:40 AM
