Stuck on heat after stereo install
Old Jan 14, 2020 | 06:05 PM
timb66's Avatar
Default Stuck on heat after stereo install
Hey gang, I have a 2007 H2 and just replaced the stereo head unit. After getting everything installed and back together, my heat is on high. Any ideas what I might have jiggled loose??
Old Jan 14, 2020 | 06:49 PM
"Jiggle loose".. brings back many memories of those dancers at the bar.
Old Jan 14, 2020 | 07:18 PM
timb66's Avatar
Amen brother!
Old Jan 14, 2020 | 07:40 PM
Disconnect battery terminal, open door, turn on headlights, etc, to release the battery memory effect. Then reconnect your battery terminal and recheck operation.
Old Jan 14, 2020 | 07:54 PM
timb66's Avatar
Interesting...so I cut battery negative, switched stuff on and reattached battery negative. Now passenger side is cold, driver hot with setting on lowest temp (60). Is it possible I hosed up the blend actuator for the driver (behind the glove box, I believe)??
Old Jan 14, 2020 | 07:58 PM
I don't understand "hosed"? Do your fan settings work?
Old Jan 14, 2020 | 08:00 PM
timb66's Avatar
Apologies, yes, fan switch adjusts fan speed as expected, just hot temp on driver side, cold on right.
Old Jan 14, 2020 | 08:06 PM
you are unable to switch blendoors?
Old Jan 14, 2020 | 08:16 PM
Old Jan 14, 2020 | 08:21 PM
timb66's Avatar
I can adjust the temp up and down on the passenger side and passenger vents behave as expected. Regardless of the temp setting on driver side, the output is hot air from the driver vents (and rear).
