Squeak Noise
Old Sep 24, 2024 | 08:33 AM
HummingBee's Avatar
Default Squeak Noise
For some reason my 2004 hummer h2 has developed this weird squeak noise that’s the loudest around 1-5 mph and is in rotation with the wheels. Hopefully I can post the video and someone can give me some ideas. Thanks guys.
Old Sep 24, 2024 | 10:00 AM
zenith's Avatar
Wheres the sound coming from? Could be many things. Front? Rear? Which side?
Old Sep 24, 2024 | 12:44 PM
RobertDez's Avatar
Isolate which wheel. Put it up in the air and spin by hand. If you can duplicate the sound you will find it really quick. Warped rotor, worn brake pad, axle bearing in the rear or front hub bearing in the front, could even be the CV axle up front. Or you may discover it's not even at one of the wheels, sound travels and it could be a u-joint on the way out in the front or rear drive line. But that's where to start before moving on to bigger things and possibilities.
flashinq
Sep 7, 2023 12:45 AM
niccor85
Sep 28, 2021 08:42 AM
Ewmoore99
Jan 23, 2017 02:30 PM
Justinh
Feb 20, 2014 07:23 PM
Jap
Feb 7, 2007 11:40 AM
