spray coating hummer h2 recommendations
Old Jun 15, 2020 | 04:57 PM
apollo18's Avatar
Default spray coating hummer h2 recommendations
hey guys! i forgot what the name of the coating is but about 10 years ago i got my truck sprayed black, its like black paint with liike a rough texture on various parts of the vehicle (foot steps, front fog light area, rear area near the exhaust)
well that coating doesnt have the black shine to it anymore and it started breaking away and rusting so i decided to get it done again, i am also thinking of getting the undercarriage sprayed
in this day and age what would you guys recommend to get? just do the same thing again? or should i get a diff material etc i forgot the name of what the coating is called
thx
Old Jun 16, 2020 | 10:36 AM
LoJac963's Avatar
Sounds like any run of the mill bedliner. The mains ones around me are Line-X and Inyati. I did a bunch of parts on my rig with Raptor Liner which I did myself and it has held up better than the professionally sprayed bed in my last truck.
Old Jun 20, 2020 | 10:07 AM
clsimmon's Avatar
The factory touch-up is GM 12378398 Rubberized Aerosol Undercoating. You might also want to check out this reference: https://www.genuinegmparts.com/pdf/t...ent-repair.pdf
I too plan on doing a frame-off chassis restoration, just haven't found the right place that is meticulous enough to sand blast and restore without damaging other components, plastics, wiring harnesses, etc. in the process.
lmazzola
Jun 21, 2019 12:09 AM
FilthyKings
Apr 19, 2012 08:39 AM
jonbishop32
Feb 22, 2011 06:17 PM
RGERBER
Jun 13, 2010 08:02 AM
jakobe
Feb 9, 2009 05:09 PM
