Spec ohm rating on a lq4 2004 hummer h2
Old Aug 14, 2020 | 06:34 PM
Shugoki's Avatar
How come when I send a message in this forum it will either post or get sent off for a review?
Old Aug 14, 2020 | 11:12 PM
i never had the issue. do you use a vpn?
Old Aug 15, 2020 | 04:39 AM
Shugoki's Avatar
Nope just WiFi. It's happened twice.
Old Aug 17, 2020 | 08:41 AM
clsimmon's Avatar
i disassembled my clone and i was surprised to see superb quality of it. it was either original manufacturer design or maybe even better. it even had gold plating on the internals there connectors and pins. the only thing that needed work where the cable end adapters as those where only tin plated and needed a bit of dielectric grease to get them to feel smooth and not bind and fully lock into the cable end.
It does seem to be high quality. I had a shorted to ground cig lighter which blew the fuse and carried forward to the obdII connector. I made the mistake to plug the external 12v cig lighter connector in to a rear seat receptacle to get the voltage to the Tech2 that I needed to troubleshoot. I immediately smelled electronics burning and a small amount of smoke coming from the bottom of the unit before I could remove the power.
I thought for sure the unit was fried, however it seems to still be working fine. I know I fried something, just don't know what. Lesson learned, if you're cig lighter fuse is blown, do not attempt to use your Tech2
therealdougkelly
Mar 10, 2017 06:47 PM
2004 H1 Wanted
Dec 19, 2015 02:09 PM
BumChuck
Jun 6, 2014 06:08 AM
Montana1
Mar 26, 2013 09:50 PM
kinghudda
Jan 8, 2009 11:23 AM
