Sp205
Old Apr 26, 2026 | 10:09 PM
XLRH2's Avatar
Default Sp205
Trying to diagnose eletrical issues with my H2.
Researching "SP205" appears to be a good diagnostic point as it allows you to isolate individual modules.
Found what i believe is SP205 but it is sooo deep/up under dash that it is impossible for my sausage fingers to do much more than touch it, nevermind testing pins,
How do I access?
*would removing the corresponding fuse for specific modules have the same effect? Zero clue how to access to check pins.
Old Apr 28, 2026 | 11:48 AM
RobertDez's Avatar
I have a chair that's close to the height of the floorboard.... Open the driver's door and position the chair. A good cushion helps. Get comfortable laying on your back with the back of your head on the floor mat. You'll be doing this eventually when your brake light switch at the top of your brake pedal quits, LOL.
Old May 9, 2026 | 12:31 PM
oceanbrave's Avatar
Modules are connected in parallel across the Serial Comms bus which is why a faulty one can cause so many problems. Pulling a module's fuse doesn't disconnect it from the bus, pulling it's link in SP205 does👍
Old May 9, 2026 | 07:13 PM
A long time since ur last post, lost at sea?
Old May 10, 2026 | 07:28 AM
oceanbrave's Avatar
Indeed been busy, hopinto get back into it👍
Old May 10, 2026 | 07:14 PM
Also been busy with new construction inside over the winter months, now closing in on the proper weather for my new plan this year to extend driveway parking pad WIDTH>PLUS1=4WIDE
Old May 11, 2026 | 06:46 PM
Mark R's Avatar
What Happened to the "USMC FLAG"..??? Did the Commandant Article 15 your Hiney?
Old May 11, 2026 | 07:34 PM
I still got it yet a bit faded, however VINE recently sent me a high quality O-H-I-O flag to display.
Old May 11, 2026 | 07:58 PM
Mark R's Avatar
Sweet...
PGI Conch
Jan 19, 2025 07:39 AM
PGI Conch
Dec 4, 2023 05:04 PM
Dogie Daddy
Jan 25, 2022 05:14 PM
paultimmins
Oct 11, 2011 09:30 AM
gio
Sep 30, 2007 09:18 AM
