Small motor with plastic fan in headliner of a 2007 H2 Hummer what is it
Old Feb 5, 2023 | 01:17 PM
Alyssa203's Avatar
Default Small motor with plastic fan in headliner of a 2007 H2 Hummer what is it
Hey everybody hope everybody's having a blessed day can anyone tell me what the little motor in the headliner above the driver side is because it is constantly running even when car is off wondering what fuse controls it
Old Feb 5, 2023 | 02:33 PM
ambient temp sensor for the climate control.
Old Feb 5, 2023 | 03:29 PM
Old Feb 5, 2023 | 03:47 PM
oceanbrave's Avatar
Alyssa203 are you 100% certain "it is constantly running even when car is off" as you described?
Asking because there is no fuse, instead it's driven directly from the Climate Control Module in the console (HVAC) If you turn the A/C off (Lower LH button) or open a door with the ignition key removed, the little fan should stop. If not it could be a faulty Climate Control Module (HVAC - expensive)
There is a YT video about the Aspirator, you can see the wiring details starting at 2:19
The Aspirator P/N is
GM 22834330, it's cheap and can sometimes just be repaired.
Hope these comments help you and if so please let us know.
[Awaiting Resolution]
dan385
Feb 25, 2014 05:27 PM
Tag37
Oct 21, 2012 02:00 AM
08grayH3
Jun 11, 2012 07:58 PM
wkrpinnick
Aug 4, 2011 05:22 PM
