Small H2 lift that retains air suspension?
Mine just slightly rub with 37's but not ll 37's are the same and the wheel offset plays a role as well.
I ended up going with the Fabtech 6" lift its in the shop being installed now.
This is before the lift with the 37's.
You can lift the front 2" using the inexpensive pucks that can be found online. Then you need to have someone reprogram the air suspension to match the greater height. All in all you can pull off a 2-2.5" lift with minimal effort. I did this on my 03 adventure series. just lifting the front will also work when the truck is running because it will try to level itself, but without the programming, the rear will droop to stock height in a day or two .
I have a 2005 H2 SUT. Im going up to 37" tires from the 35" Im running now. I would like to add a small lift. Is there one available that retains use of the air suspension? I trailer with this truck and really like the air suspension.
Or, is there an air suspension kit for the front? That would be kind of cool to be able to adjust height front and back.
Heater
Mar 19, 2013 12:23 PM
LoJac963
Aug 5, 2011 10:19 AM
johnny010
Jan 13, 2011 12:06 PM
