Skid Plate on Lifted H2
Old May 9, 2022 | 06:13 PM
skvirdi's Avatar
Default Skid Plate on Lifted H2
I recently had my 2004 H2 lifted with the Bulletproof 6-8" lift and put it on 40s. However, this resulted in the stock skid plate/mesh not fitting anymore. Anyone has experience with this scenario? If so, what aftermarket options are available? Any suggestions?
Old May 10, 2022 | 12:01 AM
finall's Avatar
1. Chop your OEM skid plate to fit.
or
2. Get a custom-fit plate made out of 1/4" aluminum by the same offroad performance shop that jacked up your H2.
Simple.
Old May 10, 2022 | 10:21 AM
skvirdi's Avatar
or
Simple.
Option 1 didn't pan out and the shop that did the lift for me does not do skid plates unfortunately. Looks like the only option might be to get a custom plate made.
Old May 10, 2022 | 10:31 AM
FatJay's Avatar
Call up your local steel shop and get plate steel or aluminum, measure, cut, bend, and drill where you need. Cost would be under a hundred bucks. You could even get it in diamond plate.
Old May 10, 2022 | 10:50 AM
finall's Avatar
OK, Best bet is to find a place that specializes in off-roading. If they can not fab a skid plate, they will know who can do that for you.
It is actually a very simple procedure.
I have had one made before for a low car that I used to drive on gravel logging roads with, whose oil pan I wanted to protect.
Old May 10, 2022 | 02:09 PM
skvirdi's Avatar
Sounds good - thank you!
Doch123
Jul 15, 2021 11:09 AM
mcioci
Sep 15, 2016 11:02 PM
Crawdaddyjc
Jun 15, 2016 04:25 PM
Estrates
Feb 24, 2013 08:29 PM
Nxsov180db
Jun 8, 2008 08:42 AM
