Side mirrors not going up or down
Old Feb 11, 2020 | 07:59 AM
firmani99's Avatar
Default Side mirrors not going up or down
Both of my side mirrors adjust side to side fine but not up and down. Since it is both of them I assumed it was the button, but I noticed that even if I have reverse tilt turned on they don't tilt when I reverse. Could both of the mirrors be damaged or is there some other module or something that I am not thinking of?
Old Feb 11, 2020 | 10:25 AM
oceanbrave's Avatar
The Driver's and Passenger Doors have individual control modules, so it sounds like they are both inoperative mechanically.
What is the history? Were they like that when you got the truck or have the they subsequently stopped working?
If they've never worked, check the wiring inside the mirror housings, also it would be good to get some pics of an 08 mirror assembly.
I don't have details for an 08 but attached is thewiring for an 06 for your ref.
Old Feb 11, 2020 | 05:46 PM
firmani99's Avatar
Thank You! I should have mentioned that I just got the truck and they haven't worked since I got it. I also suspect the motors. Something just dawned on me, maybe the previous owner had them set to both go down when reversing and the frequent up and down damaged that part of the motor.
Old Feb 12, 2020 | 04:25 AM
oceanbrave's Avatar
The motors themselves will be fine, its more likely to be the tiny little rack+pinion plastic gear mechanisms which are notoriously prone to getting damaged, over enthusiastic car-washes might be a cause, who knows,
If you look at the bottom RH corner gear you can see a break in the white plastic. Also the plastic "rocker-arm" ( the arrow shaped part with numbers printed on) often break as well as the main housing it pivots-on, the pivot is in the middle underside and hidden from view in this pic.
If you operate the mirror up/down you should hear it trying to move, if not then it could the wiring related (which would be preferable)
Your wiring may look as below or could have a single connector as in the later
Unfortunately replacement mirror mechanisms are hard to find and individual plastic parts are not available to the best of my knowledge. eBay is a good place to look, I believe a Silverado mech may be compatible.
As you can tell its a passion for me.
Old Feb 12, 2020 | 07:40 AM
firmani99's Avatar
Thanks for all of the details! I have heard that an 08 mirror is different than an 06. Do you know anything about this?
Old Feb 13, 2020 | 04:17 AM
oceanbrave's Avatar
I have but until I see some pictures or details I can't say what the differences are, perhaps someone else on the forum can help with this question?
Old Feb 13, 2020 | 04:23 AM
oceanbrave's Avatar
Found this thread - it seems the mirror assembly has been re-vamped
Old Feb 13, 2020 | 04:26 AM
oceanbrave's Avatar
Old Feb 13, 2020 | 07:08 AM
firmani99's Avatar
Awesome!! Thanks again!
Old Feb 14, 2020 | 10:48 AM
clsimmon's Avatar
just to confirm you have it set within your settings for curbview to be passenger and/or driver, and you don't have the L/R switch set in the middle?
myxomycota
Sep 9, 2008 08:59 PM
myxomycota
Sep 9, 2008 08:57 PM
dizzy
Oct 24, 2007 02:33 AM
jaycen29
Jul 18, 2006 04:50 AM
jaycen29
Jun 29, 2006 01:28 AM
