Service Air Bag light HELP!
Old Nov 7, 2019 | 07:34 PM
Originally Posted by NoSpoon
HUMMERZ, you are the man!
I found the 3100j at my local auto parts store, picked it up and it reads B0026 Driver Frontal Deployment Loop Open. Now I am trying to search for answers for that code.
Thanks for the help!
I posted a tsb above, could be a connection contact issue, however, I don't know,if there were any repairs performed that would allow the steering wheel to travel too far destroying the clockspring?
Old Nov 7, 2019 | 07:52 PM
NoSpoon's Avatar
WOW! You guys are on it! I appreciate the help. I have not had or made any repairs that would have caused this in over a year. It sits most of the time, I drive it on weekends sometimes. This just showed up one day. I will read the TSB thoroughly and see what I can test and figure out. I will report back and/or ask more questions.
Thanks again!
Old Nov 7, 2019 | 08:33 PM
Thanks again!
The proper equipment is the key! Now you know where to look. GL
Old Nov 7, 2019 | 08:47 PM
NoSpoon's Avatar
Thank you sir!!!
Old Nov 8, 2019 | 08:44 PM
NoSpoon's Avatar
I have come to the conclusion that I am going to get a new clock spring and swap it out, unless someone has a better idea.
Old Dec 30, 2019 | 05:00 PM
NoSpoon's Avatar
I finally got the new clockspring and some time to do the job. Not too bad, just takes some time to get all of the plugs and wiring harness out and the new one in.
Service Air Bag light went out!!! I appreciate all of the help and support!
Tim
Old Dec 30, 2019 | 09:33 PM
Nice work!
Old Dec 31, 2019 | 07:37 AM
mulepic's Avatar
I purchased the 3100j and my code is B0085-0F: Left Front Side Impact Sensor Signal Erratic. I need to do my search.
Old Jan 1, 2020 | 09:50 AM
NoSpoon's Avatar
When doing my research into my problem I found that others have had one of the two front impact sensors crack from over tightening or whatever. This would allow moisture inside the sensor and this could cause your issue. One easy way to check this would be to swap sensors and see if the problem changes to the other side, this way you would know its the sensor and not the wiring to it. Good Luck!
Old Jan 1, 2020 | 10:00 AM
mulepic's Avatar
Thanks for the info. Before the scanner I assumed it was one of the front sensors b/c that's a common problem. But glad I waited till I got the scanner and see that it's actually a side impact sensor in the driver's side door and I didn't waste time/money on the front sensor.
