Seat Heater Function Uncontrollable
Old Dec 22, 2020 | 12:39 PM
lamboman's Avatar
Default Seat Heater Function Uncontrollable
Has anyone experienced their Hummer seat heating to randomly turn on/off? I have a short video of it but apparently this forum doesn't allow uploading of it.
Old Dec 22, 2020 | 06:21 PM
Did you try to reset memory seat?
Old Dec 23, 2020 | 12:15 PM
lamboman's Avatar
No that has nothing to do with it. It is a short of some type or malfunction of a relay/switch/etc.... I posted a Youtube video of the situation:
Old Dec 23, 2020 | 01:39 PM
NO you didn't try to reset, or NO you don't have the time?
Did you check battery voltage/capacity & alternator output?
After that, time to jump in with the multimeter, check wiring/connector to the switch & seat heaters.
Old Dec 24, 2020 | 12:11 PM
lamboman's Avatar
Fair point I should have instead clarified that NO I have not tried the reset, but the reason is simply because I know that is unrelated to this issue. It is a faulty tripping relay or button switch somewhere I surmise. Because I can hear a relay "clicking" on and off during the constant cycling of the seat heater as shown in the video.
Old Dec 24, 2020 | 12:21 PM
you can carefully remove and open the seat heater switch and clean it with alcohol and a swab. sometimes water gets in them from leaks or rain and causes a bit of corrosion
Old Dec 24, 2020 | 01:01 PM
Yes the relay is losing signal therefore "clicking". I don't get why your driving in the video, doesn't happen when parked?
Old Dec 26, 2020 | 08:24 AM
calif phil's Avatar
Wasn't there a TSB for the seat wiring rubbing on a bracket up under the dash by the emergency brake pedal?
Old Dec 26, 2020 | 04:42 PM
lamboman's Avatar
Yes I think it does happen even when parked. But driving will usually trigger it faster I think when hitting bumps and whatnot but that may not be the case.
I'm not sure what you are referring to....? Unless you are saying there might have been a recall on seat wiring rubbing on a bracket under the dash?
Old Dec 26, 2020 | 05:29 PM
Technical Service Bulletins (TSBs) are recommended steps and procedures for repairing vehicles. A TSB is issued by an automaker when there is a growing trend with an unanticipated problems.
