Sat radio No Signal
Old Mar 8, 2019 | 07:22 PM
Sirina2's Avatar
Default Sat radio No Signal
The other day my sat radio on my 2005 H2 would display No Signal. Later it started working again. Then it quit again and said No Signal. The AM and FM and CD player work fine. Where is the sat radio antenna connection? Any advice on other causes?
Old Mar 8, 2019 | 08:11 PM
hmer's Avatar
behind your glove box there should be a metal looking like box thats the XM module there is one wire harness connector and next to that is your antenna connector check to see if its lose or just follow the cable and check the antenna itself depending where is at that may be your problem .
Old Mar 9, 2019 | 09:10 AM
There is also an in-line connector on the coax cable for the antenna under the headliner. If that antenna has leaked, or potentially even other more common roof leaks like the sunroof drains being clogged or the clearance lights leaking, and water got to the cable than it would run down the cable and potentially corrode the connectors. Depending on the specific options the longer cable will either plug directly into the digital radio box hmer mentioned or it might connect to another shorter cable near the digital radio box and then plug into the box. So you really have a few places to potentially check. Could even be that the antenna itself has had water get into it internally and is going bad. The XM antenna is the small one on the drivers side on the roof. The flat part of it is for XM, the little mast that sticks up is for the Onstar cellular communications (it is a dual function antenna).
Old Mar 9, 2019 | 04:00 PM
Sirina2's Avatar
Thanks to both of you for your advice. Will let you know what I find.
Selandbe
Dec 18, 2014 08:51 AM
Threedog
Jun 29, 2014 05:41 PM
dakota74
Mar 19, 2010 07:48 AM
HumV
Nov 13, 2007 01:00 PM
wellperfused
Nov 9, 2007 02:17 PM
