Roof markers wont light up after replacement
Old Jan 28, 2021 | 02:42 AM
HUUMHER07's Avatar
Default Roof markers wont light up after replacement
I replaced the marker lights on my 07 h2 and now all four corners wont light up. Any suggestions? Thank you
Old Jan 28, 2021 | 08:30 AM
calif phil's Avatar
Replaced them with LED lights? Sometimes you need to reverse the polarity on LED's
Old Jan 28, 2021 | 12:14 PM
coffeydp's Avatar
Def try switching the bulbs around. Turn your lights on and test which position is correct
Old Jan 29, 2021 | 06:14 PM
wpage's Avatar
Be certain you have a good ground.
Old Jan 29, 2021 | 06:48 PM
Also, if you bought a new set of lights on eBay that came with bulbs. Pull each one back off and get good bulbs. The 194 bulbs that come with eBay lights are often junk with tarnished wire contacts. You can scrape them with a razer blade, make sure the contact wires are straight and usually get them to work though but they also tend to not last as long either. All this is if that is what you used anyways...
Old Jan 29, 2021 | 07:32 PM
fastNYsix's Avatar
I just replaced the interior festoon bulbs in my truck with some leds I got from amazon. They are very bright, and quality is good. The brand is siriusled
ski.dive
May 26, 2020 12:01 PM
duffy2092
Jan 7, 2014 04:06 PM
googie714
Oct 6, 2012 08:32 AM
Hummer2006h3
Mar 3, 2011 07:36 AM
mgurgone
Jun 23, 2007 12:30 PM
