roof marker light removal/covers?
Old Aug 17, 2007 | 03:48 PM
CRXMA22's Avatar
Default roof marker light removal/covers?
just wondering if there's anyflush mount covers for the h2 that will eliminate the holes left behind when i decide to remove the lights on the roof... any info appreciated
Old Aug 17, 2007 | 06:31 PM
ZYNE's Avatar
Default RE: roof marker light removal/covers?
Prolly not.... why not go with a smoked lense instead .. I ordered me a set last year not quite sure whether I liked them or not .. but ended up looking real good. I don't like the stock lenses either and would rather do without the whole thing rather than have em on .... the smoked ones were a great compromise though. I think I posted some pics SOMEWHERE ... try searching on smoked roof lights marker or something of that nature.
Old Aug 17, 2007 | 09:01 PM
Muddydawg75's Avatar
Check your state before you just go and yank them off.... they are there for a reason....
I.D. , CLEARANCE LIGHTS, AND
REFLECTORS:
Part §393.11 requires a CMV that is 80 inches or
more in width, to have lights marking the extreme
width and height of the vehicle. I.D. and clearance
lights are required on the front and rear of the
vehicle. Reflectors are required on each side, front
and rear, of all CMV’s regardless of the vehicle’s
width. These light and reflector requirements are
also covered under State statutes.
Old Aug 20, 2007 | 10:14 AM
CRXMA22's Avatar
thanks, for the info guys. i may just compromise and go with the smoked lenses all around the car instead of yanking them off.. or just remove the middle three and leave the two top edge markers on..law enforcement is pretty strict around my neighborhood
for some reasoni just don't like theorange lights?? i just don't understand why my tahoe doesn't need them but my hummer does?? they sit at about the same height. but what do i know... what to do, what to do....
Old Aug 23, 2007 | 03:10 PM
GorillaH2's Avatar
What did you end up doing and where do you get smoked rooflights?
Old Aug 23, 2007 | 06:14 PM
Believe it or not... it's not height that requires them... but width....
It could be perfectly legal to take them off... which is why I said check if you really want them gone...
Old Aug 23, 2007 | 07:21 PM
GorillaH2's Avatar
i have a really good joke for this. Damn it!!!!!!
Old Aug 24, 2007 | 06:57 AM
Adrian3841's Avatar
Default This is what I did
I am in the same boat as you are, so I wanted to remove the front middle marker lights since I do not want H2 to look like a semi.
I removed the three center lights and used the sheetmetal plugs to plug the holes and gave dab of clear RTV. Looks perfect!!
you will need two different size plugs for this and I got it from http://store.nutsandbolts.com/sheet-...ole-plugs.html
[IMG]local://upfiles/3046/9F138225561E473BA0327DC793758FEE.jpg[/IMG]
Old Aug 24, 2007 | 03:46 PM
CRXMA22's Avatar
Default RE: This is what I did
gorilla, and the joke is...... (drum roll)
thanks for the info muditis a hell of alot wider..
adrian3841, i might go that route for the meantime until i fab up some flush mount carbon fiber looking brackets...what size capsdid you get??
Old Aug 27, 2007 | 06:02 AM
Adrian3841's Avatar
Default Size pugs
you will need 6 of 1/2" and 3 of 1-1/4" to do the front. Now, this is just for the center three front clearance lights.
I just got a killer deal on the Recon smoke clearance light package and installed this weekend. It appears solid black, but nicely lit when the lights are on.
I will shoot some pictures.
