Roof Gutter Seam Seal Rotted
Old Jun 24, 2021 | 11:02 PM
mine has black moulding there
Old Jun 25, 2021 | 01:18 PM
HellHoof's Avatar
Originally Posted by MixManSC
You are missing the entire main inner trim part of the roof rack.... Only pic I have handy from right after I got mine (already replaced that FM antenna - 2003 was the only year with the antenna on the roof by the way).
Are you referring to this part in yellow? Is that trim? I figured that was your roof sealer...
Not sure if 08/09 are truly any different but here is one that says for 08/09 for one side. https://www.ebay.com/itm/133021224778
There are others on eBay as well. It is one piece and goes under the metal rail. I can only guess your are either broken or intentionally cut off for some reason.
Looking at those pictures, I'm not seeing anything different from what I've got on mine. It looks like the roof rack rail is built in part of this which is what mine looks like....right? I'm very confused now.
I wish they had actual pictures. This part doesn't seem to be listed for 2008-09, do they have one? Looking at the roof diagrams on 08 I don't see anything like this.
Old Jun 25, 2021 | 01:19 PM
HellHoof's Avatar
I meant to attach this...
Old Jun 25, 2021 | 01:44 PM
Old Jun 25, 2021 | 02:05 PM
Old Jun 25, 2021 | 02:17 PM
HellHoof's Avatar
Well it looks like, at the very least, I need to put some new seam sealer on. That link for Trueline Automotive seems pretty nice too, although I question if it's just plastic 3M taped on the gutter, will it actually help divert water away, or would it end up trapping it in there?
Old Jun 25, 2021 | 02:22 PM
Obviously pack in the sealer first, then cover that mess with trim. Call them and get more information.
Old Jun 25, 2021 | 03:41 PM
nothing special about it it is there to hide and protect the seam sealer. mine is lifting up a bit. need to tack it down with some 3m trim tape
Old Jun 25, 2021 | 06:31 PM
Forget the tape, just stick it back in place with seam sealer to hold it. Most any brand will work, or you can go with
ACDelco GM Original Equipment 10-2013 Body Joint and Seam Filler Compound ACDelco GM Original Equipment 10-2013 Body Joint and Seam Filler Compound
Simply apply under the trim, press/hold/put weight on/until it cures.
Old Jun 25, 2021 | 06:45 PM
Btw, that trim appears narrow, and the seam appears exposed?
