Reverse light wire location
Old Jan 7, 2023 | 09:54 AM
bagpype's Avatar
Default Reverse light wire location
I’m installing a reverse camera on my 2003 H2 and I need to tap into the reverse light signal. I have searched and searched and have come up with nothing besides someone mentioning a wire at the rear view mirror. This seems difficult to say the least. I’m stuck at this point and really need some help to figure out where a reverse light wire is in the cab of this H2. Any guidance??
Old Jan 7, 2023 | 12:20 PM
PGI Conch's Avatar
Hope this helps.
Old Jan 7, 2023 | 01:11 PM
there should be reverse at the tow connector on the bumper
Old Jan 7, 2023 | 02:52 PM
PGI Conch's Avatar
If you are looking for reverse power in the rear, the 7 pin trailer/tow connectors typically have backup (reverse) power on the center (#7) pin. That worked for power when I added a camera to my H3. Probably the same on the H2 (mine isn't home right now to verify). If you need it to energize the interior/dash monitor then the previous dash area schematic should help.
MeBelovinMyH3
Jan 8, 2009 09:22 AM
lucky19942001
Nov 27, 2008 08:46 AM
BabyTank
Apr 15, 2008 01:09 AM
weissgmd
Apr 1, 2008 09:54 AM
crank
Apr 1, 2007 09:05 PM
