Replacement windshields
Old May 22, 2021 | 02:13 PM
fastNYsix's Avatar
Default Replacement windshields
Has anyone had a windshield replaced? I accidentally clipped the edge of mine while prying cowl off. It’s not noticeable with cowl on and I was debating getting a new one. The internet shows 03-04 is different than 05-09. Wondering if anyone has some info on this. I’d want a real gm one not Chinese. Thanks
Old May 22, 2021 | 02:26 PM
"Clipped it"? If less than 1-1/4" repair with Permatex® Windshield Repair Kit
Old May 22, 2021 | 05:26 PM
The picture I showed of mine with the cowl off - the white where the windshield should be is vinyl. I put that on temporary to keep water/dirt out. Here in SC if you have full coverage a replacement windshield is free. I had a local place come pull the old one then come back after a couple of weeks to put the new one in. I did ask for genuine GM and they were fine with that. I left it out for a couple of weeks since I wanted to redo the headliner and that is easiest to remove through the windshield opening...
Mine was pretty pitted from years of being sandblasted on the road and had a ton of glare from that. Crystal clear now.
Old May 22, 2021 | 05:59 PM
fastNYsix's Avatar
https://youtu.be/5eupXcI8hH8
yea I was rotating the pry bar and I heard crunching. I thought it was fiberglass from the cowl but it was glass. Appeared to delaminate. 1/2 inch by 1 inch long. It’s under cowl so you can’t see it. It might last years. Idk. Might not.
Old May 22, 2021 | 06:02 PM
fastNYsix's Avatar
Nice. I assume you pulled cowl not glass company. The 05 up windshields appear to be cheaper for some reason. Is there any difference in windshields? Also did yours come with a new weatherstripping across the top?
Old May 22, 2021 | 07:22 PM
Repair the damage to prevent further damage.
Look at the possible damage a spark plug could do:
Old May 22, 2021 | 07:56 PM
fastNYsix's Avatar
https://youtu.be/EE7ug2okU-E
I just found out about the spark plug truck recently lol. I want to try it some time.
Old May 23, 2021 | 05:22 PM
finall's Avatar
New OE glass is still available via GM, whatever years are the same as 2007.
I just had my 07 windshield replaced. Came with new top weatherstrip ( which is falling off, so back to glass shop in the next few says)
Old May 23, 2021 | 05:56 PM
fastNYsix's Avatar
Ok thanks. I’m going to call glass shop tomorrow and see what they say.
Old May 23, 2021 | 06:42 PM
Try diy repair first. If you decide to go with replacement? I highly recommend Safelite.
