Rear wiper not touching
Old Jan 9, 2020 | 02:13 PM
hnijhar's Avatar
Default Rear wiper not touching
I went to get new wipers for my 2003 hummer h2 and replaced the rear one as well but noticed it doesn’t touch. I guess that way my problem all along and probably didn’t need to change it. It seems like the spring isn’t strong enough anymore so is my easiest fix just to bend the arm? Or what do you guys tecommend
thx
Old Jan 9, 2020 | 03:09 PM
XLRH2's Avatar
Check that spring is attached and working correctly, Double check that you have installed wiper correctly (with correct adapter) and if all checks out, bend it slightly, spring should be under very minor pressure when wiper is against window.
Old Jan 9, 2020 | 03:16 PM
Silicone spray the hinge then work it back and forth. if you pull the blade off the window, and release, should snap back.
Old Jan 10, 2020 | 07:08 AM
sean04h2's Avatar
Default Rear wiper blade
I have the same problem on my 2 H2.
I'll try to do that.
Old Jan 10, 2020 | 07:14 AM
I know others have just gone ahead and replaced the entire arm since a new one has a new spring. Mine works but misses about 25% at the far ends of the wiper. I did get a Piaa replacement blade which helped but the spring in the arm itself is just worn out. I have not looked close enough to see if there is some way to help that on the existing arm.
Old Jan 10, 2020 | 02:48 PM
sean04h2's Avatar
Default Rear wiper
I cant seems to find a piaa silicone for rear wiper blades 10"
Does anyone know were to get them?
Old Jan 10, 2020 | 03:29 PM
Old Jan 10, 2020 | 08:39 PM
sean04h2's Avatar
Thank you for the links 12" wiper blades
I'll order them today.
Old Jan 11, 2020 | 07:02 AM
hummer_on_fumes's Avatar
There is a 99% chance you're also going to need the rear wiper arm because I had the same problem. Part number is 88944328, it is on eBay for 39$. I tried bending my old arm with pliers and just couldn't get it right. The new one made everything work again.
Old Jan 11, 2020 | 07:11 AM
sean04h2's Avatar
Oh I see, ok I'll try my blades and if it does doesn't change at all then I'll get the arm.
thanks for the link info.
