Rear Window Inop Unless Door is Open
Old 04-28-2017, 09:42 PM
clsimmon's Avatar
Default Rear Window Inop Unless Door is Open
So, I have a very confusing situation. My rear left window will work unless the door is open. This is true from both the driver switch and rear left passenger switch. I have pulled the boot within the door jam and nothing appears to be broken. I closed the door latch manually to trick the truck in to thinking the door was closed (interior lights go out) and window still works while open so it doesn't appear to be an electrical draw issue on that door.
Any ideas? By the way, does someone have a pin-out description of that rear left window switch connector that I could reference?
Jeff Bartnett
08-17-2016 07:21 PM
juicebox123
05-19-2015 02:51 PM
johnmully
09-14-2013 11:51 AM
Chad1996
12-01-2012 02:21 PM
HummerGuy
02-18-2007 10:17 PM
Quick Reply: Rear Window Inop Unless Door is Open
