rear door lock switch/mechanism is sticky, how to fix
Old Mar 1, 2020 | 03:52 PM
apollo18's Avatar
Default rear door lock switch/mechanism is sticky, how to fix
hey guys in my 2003 hummer h2, both the rear door locks are sticky. when i try manually pushing the door lock switch, they are hard to push and dont slide as easily as the front ones. so whenever i unlock or lock the truck, the back ones either dont lock or dont unlock or are half way, where there door will open half way but not fully. how can i fix this? do i just lube up the door lock actuator with wd 40 or something or do i have to replace something in both doors?
thx
attached is a photo of what i am talking about
Old Mar 1, 2020 | 05:43 PM
DON'T USE WD40!
I only use, click here>>>>> PB Silicone Lubricant
Old Mar 1, 2020 | 05:44 PM
apollo18's Avatar
so just spraying my door lock actuator area should fix it? or is it something else
Old Mar 1, 2020 | 06:07 PM
Spray silicone lube to free it up, you may need to pull the door panel and spray the linkage, actuators, etc...
Old Mar 1, 2020 | 06:08 PM
apollo18's Avatar
sounds good thx
Old Mar 2, 2020 | 07:25 AM
hummer_on_fumes's Avatar
sounds good thx
I had the same problem and I replaced the door lock actuators
Old Mar 2, 2020 | 09:30 AM
Agree with Hummerz..... do not use WD40. That is not a real lubricant.
Likely the plastic slide button itself is not the problem. More likely in the rods, lock actuator, etc. The factory grease on the rod slides is a white lithium grease but like many types of grease, after a number of years it starts to act more like an adhesive than a lubricant. Clean it all off and put some new grease on things and it will probably loosen up and be fine.
jsbihn
Jun 2, 2019 01:58 PM
jsbihn
Jun 8, 2016 06:58 PM
mpac165
Jun 8, 2016 10:38 AM
Shotgun76
Sep 2, 2015 12:38 PM
urockradio
Feb 1, 2010 08:22 PM
