Radiator
Old Apr 17, 2020 | 03:25 PM
Eagle's Avatar
Default Radiator
How long did your radiator last before need to replace?
Old Apr 18, 2020 | 09:22 AM
Chrmer3's Avatar
too many variables. I always replace mine right after buying any H2 (my 4th rig). Dexcool can cause some serious issues and if the coolant breaches the radiator to the internal radiator trans cooler- game over for tranny.
Cheap enough to replace and at least have a fresh start, while your at it, probably need to do tensioners, water pump and for an extra $50 the fan clutch. Flush her out good and in my opinion dont go back to dexcool. Go with regular green 50/50 antifreeze.
You can google "dexcool lawsuit" many many pissed off owners that have had major issues with dexcool....
I was lucky on my current H2, cooling system was absolutely clean with no horrific dexcool issues, once i did the above service and made sure the system was completely flushed & dexcool free I filled with green prestone 50/50..
Some take it a step farther & remove the trans lines and install an external trans cooler to eliminate any future chance of mixing / catastrophic transmission damage.
Old Apr 18, 2020 | 08:17 PM
Eagle's Avatar
Thanks for your input. 2006 with 92,000 miles. I am second owner, bought at 82,000 a year and half ago. Thinking of getting a aluminum radiator for better cooling and to assure myself of no coolant transmission problems. Previous owner had 2 H2s, I snagged this one. Very well cared for and serviced and all highway miles. This is my 3rd Hummer, 3.5 H3, 08 H3 Alpha, and this 2006 H2.
ON IT
Nov 21, 2021 08:03 AM
DetMedic507
Mar 20, 2018 01:18 PM
StormKatMan
Oct 17, 2015 05:11 PM
Hummerrican
Aug 3, 2015 07:17 PM
aces
Mar 4, 2013 09:08 PM
