Purpose of these?
Old Jul 25, 2023 | 03:49 PM
PGI Conch's Avatar
Default 2003 H2 - Purpose of these?
Curious what the purpose of the additional plastic tubes (see pic) are for? Is this just to keep hands out of the fan blades? Can't imagine it has a purpose as part of the air intake. TIA
Old Jul 25, 2023 | 07:32 PM
The fan-shroud assembly is an important component of the cooling system. While the fan is responsible for drawing in air, the fan shroud's job is to ensure uniform air distribution to the radiator core. By assisting airflow in the engine compartment the fan shroud helps in dismissing excess heat from the engine.
Old Jul 25, 2023 | 08:06 PM
those chambers act as resonant mufflers and balance the air flow into the intake.
Old Jul 26, 2023 | 05:17 AM
PGI Conch's Avatar
Ah yes, shrouding, that makes sense.
So they are internally connected to the air stream? I didn't realize they were internally chambered, just figured hand guard, and now per above the fan shroud. Which probably explains in part why those after market intake systems are "louder".
Thanks guys. Appreciate the feedback.
Old Jul 26, 2023 | 05:30 PM
finall's Avatar
Not so fast! Those are NOT part of the fan shroud if you look. The fan shroud is underneath them.
Old Jul 26, 2023 | 06:24 PM
PGI Conch's Avatar
Understood.
BCHummerH2
Aug 13, 2014 03:07 PM
pnoman
Jan 1, 2012 01:02 PM
RavenH3
Aug 23, 2011 11:29 AM
BlackH3CA
May 9, 2006 09:55 AM
hoguangtai
Apr 14, 2006 10:24 AM
