Power Seat Draining Battery
Old Oct 14, 2019 | 10:39 AM
kiyit's Avatar
Default Power Seat Draining Battery
I have a 2003 H2 and two weeks ago it started killing the battery in 4-5 hours. I mean so dead it would not come out of park and would not release the key. Had battery checked and alternator load tested. All tested good. Traced it down to the Driver's seat. unplug the harness to the drivers seat and the test light ( connected between the negative cable and the negative terminal) goes out and drain stops. Has anyone else had this issue? If i leave the harness unplugged the battery is fine.
Old Oct 14, 2019 | 11:48 AM
check the seat for cables rubbing on the rails maybe a wire has worn through and touching metal. there is also a module under there it controls the seats the heaters and seat memory. there are also modules in the doors that work with the seat module.
Old Oct 17, 2019 | 10:23 AM
Kit Andrews's Avatar
i plan on taking the seat out this weekend and looking for that type of stuff. Everything still works on the seat and when its plugged in the test light blinks in a weird pattern. Really strange stuff
scabello
Nov 12, 2017 06:53 PM
DeMopar
16
Mar 11, 2017 06:33 PM
mnext02
Sep 26, 2011 10:45 AM
Tech5
Mar 17, 2011 10:32 AM
paulwolf7200
Jun 2, 2007 10:41 PM
