PLEASE HELP!! Whining noise from Alternator?
Old Feb 4, 2023 | 10:30 PM
Alexander1805's Avatar
Default PLEASE HELP!! Whining noise from Alternator?
Please help I've been trying so hard to stop this noise but my mechanic told me there's isn't much we can do. I find it so annoying and loud. We've changed two aftermarket alternators and at the end I went to the dealership and bought a Acdelco one but it still didn't stop it. From all 3 alternators 2 of them made the same noises. Any tips and advice will help so much. Thank you
video of the sound attached here
https://imgur.com/a/m76IiVT
Old Feb 4, 2023 | 10:40 PM
its a hummer h2 2003
Old Feb 6, 2023 | 01:12 PM
I'm thinking that if the sound does not change swapping between 3 different alternators, then the sound is likely not coming from the alternator. As with many who come here with mechanical issues and questions, I'd suggest checking on one of the many GM truck or SUV forums as those use the exact same drivetrain and are far more common so more likely to find answers from someone who has had the same issue.
Old Feb 6, 2023 | 01:30 PM
have they checked the water pump or fan clutch or the tension pulleys or if the belts are worn or if the harmonic balancer is separating. maybe something out of alignment on the drivetrain?
Old Feb 6, 2023 | 03:33 PM
Ever hear of a Mechanics Stethoscope?
Did you try running without belt installed?
Do you know how many pulleys are on the front of the 6.0?
Old Feb 7, 2023 | 12:26 PM
finall's Avatar
From all 3 alternators 2 of them made the same noises.”
So, which one did not make the noise? Are you saying one was not noisy or different noisy?
Was the AC Delco rebuilt or brand new?
You sure it is not the fan clutch or something near the alternator like a pulley or glazed fanbelt?
Old Feb 7, 2023 | 06:41 PM
Idler pulley has a worn bearing.
Old Feb 8, 2023 | 03:06 PM
hummer_on_fumes's Avatar
Like everyone else said...if you tried 3 different alternators then it's not the alternator making the sound. It could be so many things. One time I had a leaking hose, the fluid got on the belt and made my H2 sound like I had a bird living under the hood. Fixing the leak and adding a new belt got rid of the noise
niccor85
Sep 28, 2021 08:42 AM
Ewmoore99
Jan 23, 2017 02:30 PM
Dirtman2009
Dec 16, 2009 10:08 AM
mliebs8
May 30, 2007 06:42 PM
Jap
Feb 7, 2007 11:40 AM
