Passcode light on all the time! OK...Everything seems to have fallen apart.
Hummer H2For those who like a little more gleam to their Hummer, the H2 offers a similar rugged look as the H1, but as a lower cost, and with more added features, making it almost a massive luxury SUV.
07 H2 BLACK, 81k miles, factory stock except for wheels. Battery was drained the other day, not normal because it is less than a year old. I noticed everything was soaked on the inside an never experienced this because up until a few months ago the truck was under shelter. Anyway, I've been sorting things out over the last week.
I had to replace the CIG fuse to get the OBD to power up.
Sealed the front running lights, and they needed it.
I pulled the blower fuse/because the damn thing was running. I will replace the resistor.
Amps were 2.14= I pulled radio fuse.
Amps are .072 for a while and slowly drop.
This damn passlock light stays on all the time.
The Pico motors are erratic on the cluster./I hope they'll straighten themselves out.
"Four wheel drive service needed" on the display but no codes. The only code I have is some evap solenoid and could not cause all this mayem/ could it?
Thanks in advance.
SaneGoat A couple years ago.
I had a similar issue on my 03 with the light on and intermittent battery drain, it was the electrical portion of the ignition switch. Cheap and easy fix.
