overheating while towing with a/c on
Old Jun 14, 2010 | 08:19 AM
Hands's Avatar
Question overheating while towing with a/c on
The other day i was bring my boat home from our lake house. i drive about 25 miles of back roads before hitting the highway. while on the back roads the engine temp was fine with the a/c on tranny temp was good , road's had hills and curves doing about 45 to 50 MPH. After getting on the high way doing about 65 to 75 MPH the engine temp started to rise one line past the 210 mark ,tranny temp was good. i turned off the a/c and the engine temp went back down. so i drove most of the way home with out a/c. I got about 15 miles or so from home and thought i would see if i could get it to overheat again by turning the a/c back on and it went back up as before and i turned the a/c off again and it went back to normal. I have a 8" coolant fan on factory trans cooler but does nothing for the engine temp or tranny temp while driving, it will cool down tranny while setting still, I had the fan on the whole way home... You have the trans cooler, then the a/c condenser, then the radiator, the added heat from the a/c condenser heating the radiator causing the engine temp to rise,the tranny temp was ok, it went up alittle but nothing like the engine temp.....ANY IDEALS......
Mike
Old Jun 14, 2010 | 08:51 AM
Hands's Avatar
Opps i forgot ..its a 2003 H2
Old Jun 14, 2010 | 08:57 PM
calif phil's Avatar
I would say a partial plugged radiator and or a fan clutch not pulling enough air. How many miles do you have on your H2?
Old Jun 18, 2010 | 01:40 PM
Hands's Avatar
Thanks and sorry it took so long.. yes i agree ...my h2 has 65000
Old Aug 17, 2020 | 07:32 PM
NeaHummer's Avatar
Old post I know but did you ever find a solution?
hifiguy
Jun 4, 2015 03:11 AM
H2CANEPADESIGN
Jan 10, 2013 08:50 PM
c3 rolling
Nov 6, 2008 08:07 AM
cgnd3000
25
Jun 20, 2007 12:05 AM
Guy
Apr 25, 2007 04:50 AM
